Old October 28th, 2019, 07:52
HuntFish 01XJ HuntFish 01XJ is offline
2001 XJ need a new radiator
I have had a 3 row csf radiator for the past 6 years, I had to replace it once already under warranty for a leak. The replacement is now leaking in the same spot🤦*♂️.
Looking for suggestions on what to go with now.
Old October 28th, 2019, 09:37
md21722 md21722 is offline
Re: 2001 XJ need a new radiator
After trying Spectra's and having them repeatedly fail around the 2 year mark, I switched to Mopar's from the dealer and haven't had any problems with them. 52079682AF.
Old October 28th, 2019, 10:11
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Genuine Jeep parts fit better and last longer.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old October 28th, 2019, 13:31
Redsnake Redsnake is offline
There's a good Radiator Review/Rating thread in here somewhere... LOTS of information there.
Old October 29th, 2019, 09:53
lazyxj's Avatar
lazyxj lazyxj is online now
NAXJA Member #1310
I looked yesterday for Cal's thread but couldn't find it, the search engine barely works anymore.
Found it using Google, it is a better place to search, even for .
Include the word "" at the end of the search request .
https://www.naxja.org/forum/showthread.php?t=1150722
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old October 29th, 2019, 09:58
I'm sending the old one that leaked out to see if they can repair it. I'll report back here with the outcome.
Old October 29th, 2019, 15:10
Down under Down under is offline
Don't forget, to replace the rubber absorption bushes. They don't like being fitted to tight. Leading to cracking at joints etc.
Lost faith in radiator flush chemicals available in OZ,
Almost drinkable!
Mate and I ended up draining the system that was gunned up with straight cheap cleaning vinegar, ran it for and hour and, soaked over night, ran it again for and hour .
Flushed well.
Did a great job.
Not for everyone perhaps.....
Old November 6th, 2019, 09:02
Sent out the old csf 3 row radiator. Has it repaired and I installed it, so far no leaks. Best part is the company my job uses for this service repaired it under "customer appreciation " and didnt charge me a dime.
Old November 6th, 2019, 09:05
That's awesome! I still have my leaking 3 Row CSF Aluminum radiator sitting beside my work bench in my garage... can't bring myself to throw out all that pretty aluminum, even if it does have a slight leak.
Old November 6th, 2019, 09:06
See if you can have it repaired like I did.
Old November 6th, 2019, 09:08
I would, but I don't know of any decent local repair shops. Plus for the price it would likely cost it's not worth it to me since I already replaced it w/an all-metal HD one.
New radiator for 1991-2001 Jeep XJ Georgia Mike SEC For Sale / Wanted Forum 0 April 21st, 2009 17:25
2001 4.0 radiator 1xfloppy SoCal For Sale 0 March 10th, 2008 15:23
Radiator Drain Plug? 2001 XJ Poppinblock OEM Tech Discussion 9 April 10th, 2006 10:21
What kind of radiator on 2001's? nosajwp OEM Tech Discussion 0 October 8th, 2004 10:31
Best aftermarket radiator for 2001 XJ... RockRod Modified Tech Discussion 11 July 5th, 2004 23:09
