built dana 30
corbinafly
"Mmmm. More please."
lakewood,ca
4.56, high pinion, non-disco
tnt truss
crossover steering/raised track bar
vanco brakes
chromoly shafts (27 spline)
ctm u-joints
ox locker
coil buckets moved back 1"
rotated Cs for good pinion angle and caster (I ran 5.5"-6" of lift)
tnt trackbar bracket with added bracing that goes to the passenger's side of the frame
raised shock mounts for racing style shocks (i ran bilstein 7100s)
JKS lower control arm skids
You'll need about 5-6" or so of lift and adjustable control arms to bolt this up. Or you can modify/fab to fit your setup.
$1500 firm/solid
come see it. come get it. be happy!:yelclap:
What brand of track bar mount (axle end) is that?
started off as a toys by troy, but I modified it to work with the truss and future over knuckle tie rod i was planning before the jeep was parted out.
Got a pic of the lower shock mount?
TTT
TTT
corbinafly.... your axle is the cause of my wet undershorts, please refrain from doing that again. ;)
GLWS
TMI man. I did not need to know that. Especially since you dangle hairily.:puke:
ttt
