Does a c-clip D35 measure the same at the neckdown than a non c-clip D35?
EricsXJ
NAXJA Member #616
Reno, Nevada
Did a search.
I'd like confirmation on this if anyone has ever seen both types of shafts. The non c-clip D35 shaft I have doesn't neck down much but the c-clipped 8.25 shafts sure do. I need to know if the c-clipped 35 necks down any more than the non c-clip version.
Kind of an odd question I know...
Before I answer the wrong question -- you are asking about the actual axle shaft, correct? Not the axle tubes?
