old_man
- Loveland, Colorado
I've been wrenching for longer than most of you have been alive and I have come across the biggest PIA I have ever had.
This isn't an XJ, its a 96 Ford Exploder with 5.0L. There are two funny bolts, studs really. They are about 3 inches long on one end and about 1 inch long on the other, seperated by a integral half inch formed nut. I stripped off the corners on the nut using a 6 point socket because it wouldn't turn. I did jamb nuts on the free end and they just turned. I welded a nut to the free end and ended up twisting off the integral nut, leaving only a 3" headless stud on two. The studs were corroded into the aluminum water pump. I ended up having to break the water pump casting to get it off the studs. I have now tried three times on each stud to loosen them by welding a nut on the stud.
I still haven't been able to get the studs free. It looks like I am going to have to strip the front of the motor and if worse comes to worse, drill out the studs in the block, drill, tap and install helicoil inserts.
I have been working on this 1 hour job for 6 hours so far. This is the original water pump with 280k miles on it.
