Mike L
- Anaheim, CA
I need a set to get more flex out of my Alcan leafs. I was debating between the JKS and the Full Traction ones. Is there any difference in the length or angles? Thanks.
-Mike
-Mike
Big Jeep 101 said:I need a set to get more flex out of my Alcan leafs. I was debating between the JKS and the Full Traction ones. Is there any difference in the length or angles? Thanks.
-Mike
Big Jeep 101 said:Actually they are needed because I have Tera shackles and the springs are a little longer and the shackle hits the back of the shackle mount box on flex and when I hit a big bump/dip.
Big Jeep 101 said:Nobody out there has any opinions? What are those with the BOR/Alcan 8" springs running for shackles?
-Mike
-Mike
Goatman said:I've never heard of anyone running Full Tractions boomerang shackles. They make good stuff, but it's not widely used. Since you asked about the difference between the two, that's a hard question to answer unless you have the exact right experience.
Make the calls.......
FarmerMatt said:I'm running the 8"s. Overall I'm happy with them, but I did have to make some changes. I bought a set of JKS boomerang shackles to run with them, but they ended up not having enough of a kick back to them to work well with the longer leafs. I had to build a set of shackles that had enough offset to them so the shackle wouldn't bottom out in the shackle box. I also had to cut out the back of the shackle box to get full motion. You may want to ask John John if he's made any changes since when I got mine.Big Jeep 101 said:I heard you are running a set of BOR/Alcan leafs. I don't know whether they are the 6" or 8" though. What shackle are you running in back? Did you do any mods to the way it mounts? Thanks in advance for your reply.
-Mike
Matt
