Rubicon Express lift kit
kamakazi bush bum
Errington BC
anybody know whats different between the RE 3.5 Super Flex lift kit and the RE 3.5 Super ride lift kit as my jeep is a daily driver id still like ok street handling but its all about the flex right
I believe the super-ride uses rubber bushings like stock at the ends and gives a smoother ride in turn and cheaper. The super-flex uses rebuildable/greasable balls like johnny joints. Flex is basically only limited by your shocks. I would go with the super-flex if your budget allows even though it transmits a little more vibe into the body. If you stay with the stock style rubber spring isolators it will help though. Don't use those lift spacer plastic ones cause your feel every crack in the road! As long as you don't have the expectation that it will feel like a Cadillac then your good. Good luck:)
that basically sums it up right there..and price
XJ&TJ4ME said:
until this thread i thought it was just that too. good to know what the difference is.
