Old February 19th, 2009, 08:28
bigdaddyjlove bigdaddyjlove is offline
Odd noise from drivetrain.
Looking for some help diagnosing a noise from my jeep.
1998 TJ (I know not a Cherokee, its my daughter's)
4.6 Stroker
AX-15
231 t-case
Super 35 with Auburn Ected
no lift
I get an odd "clunk" when going on or off the throttle. It seems to come from the left side near the t-case.
It has done this for a while, I replaced all 4 rear control arms, the trac bar is tight, the diff seems not to have any slop.
At this point I am thinking that it is either the T-case or that one of the mounts for the control arms has cracked.
I will check the mounts tonight, and I am wondering how I can check the t-case at the same time. I will have access to a lift, but it takes a pretty hefty dose of throttle to make this happen. I don't know if I can repeat that by hand.
Thanks for any help
Old February 19th, 2009, 09:12
winterbeater's Avatar
winterbeater winterbeater is offline
Re: Odd noise from drivetrain.
Motor mounts?
Old February 19th, 2009, 09:15
Motor mounts had crossed my mind. Thanks I'll make sure to check them tonight.
anything else I should look at?
Old February 19th, 2009, 10:18
comrad_zeelaagee's Avatar
comrad_zeelaagee comrad_zeelaagee is offline
u-joints or tranny mount?
Old February 19th, 2009, 15:43
Ujoints have been checked to death. I looked at the tranny mount and it seemed ok. No cracks or other obvious problems. Will check it close along with the motor mounts tonight.
Thanks
Drivetrain noise NEWYXJ OEM Tech Discussion 3 July 15th, 2009 22:26
Drivetrain Noise I need help squirrel80 Modified Tech Discussion 7 September 29th, 2008 19:36
Post Mud Bog Drivetrain Noise MountainFisher OEM Tech Discussion 6 September 2nd, 2008 14:34
drivetrain noise - grinding kellen OEM Tech Discussion 7 March 11th, 2008 21:53
Please help diagnose drivetrain noise. Powerman Modified Tech Discussion 22 June 20th, 2006 10:04
