Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
  #16
Old April 19th, 2021, 19:06
RCP Phx RCP Phx is offline
Re: Interesting "can of worms"
Originally Posted by Anak View Post
If perchance you initially scribed a line all the way down and then went back and added your tabs that could be your problem. A scribed line will act as a stress riser.
If that is not what happened, another course to consider is to anneal those sections you need to bend. It is fairly easy to anneal aluminum if you have a torch rig. Set up your torch to run rich such that black wisps are falling out the air and use that setting to lay down a coat of soot where you want the aluminum annealed. Once you have laid down your soot adjust your torch back to normal operation and burn the soot off. Once the soot has been burned off you have annealed the aluminum and can work with it as you like. If you need to harden it again afterwards I think that is going to require a shop with more specialized equipment than an individual is likely to have on hand.
I did both a heavy scribe and a torch anneal, stuff happens!
Old April 19th, 2021, 21:32
Anak's Avatar
Anak Anak is offline
Stranger
Try again on a scrap without the scribe.
Old April 19th, 2021, 22:33
sdspearo's Avatar
sdspearo sdspearo is offline
Usually not an issue on thin stock, but did you consider grain direction? At this point it may be easier to just weld the tabs back on if you got a clean break vs starting over again.
'96 XJ: Locked up D44's on 35" Milestar Patagonia's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Atlas 5.0, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old April 19th, 2021, 22:40
No, it's part my fault. I sent it to work with my son and with the intensions of a "obtuse" bend, it got over-bent to a "acute" angle that I think broke it (there was actually one survivor). I'm currently working on a piece of stainless(1/16") that will be a lot faster to re-do.
Old April 20th, 2021, 07:50
Bent's Avatar
Bent Bent is offline
FIGHT ORGANIZED CRIME
I suspect you are referring to aluminum. How is grain direction determined?
DEFY LIBERALISM
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ • 4.0 • AW4 • 231 • Modified
'87 MJ • 4.0 • AW4 • 231 • Stock-ish
SoCal Chapter Past President
Old April 20th, 2021, 08:19
It would take longer to build a jig to hold the mounting feet in place at the angle I need than to just make new ones.
Old April 20th, 2021, 09:49
sdspearo's Avatar
If you're working with a new 4x8' sheet it might be marked with an arrow, depending on mfr. If working on a salvaged or unknown piece you can sometimes see the grain with naked eye or under magnifying glass. If not, then making a couple of sharp bends on small coupons should tell you.
Old April 23rd, 2021, 09:15
The new set hot from the plasma cutter. They look a little nasty now till I get them cleaned up, but no drilling this time so it went fast. Now to get them on the brake.
Old May 3rd, 2021, 12:37
Finally getting to the end of this project, I got all my pathways figured out and all the wire pulled. Got the top penetration ready to set the panel in place. I've got a lot of wiring to do!
Old May 4th, 2021, 16:29
Bent's Avatar
Talking Re: Interesting "can of worms"
Eh, just solder all the ends together and tie the bundle in a knot.
DEFY LIBERALISM
Old May 4th, 2021, 16:50
If I tie the knot to tight the electrons can't get thru !!!
Old May 5th, 2021, 12:09
Bent's Avatar
:doh" STUPID...and I was a physics minor!
DEFY LIBERALISM
Old May 8th, 2021, 12:56
I had to make some changes to the PDU I built so I also added some identification to the breakers, I added a 10amp for the USB ports/power meter, also for on-the-road repairs ("electrical for dummys").
Old May 10th, 2021, 10:10
Got the panel up on the roof (it's not bolted down yet). It's a 200W and 29" x 62".
Old May 11th, 2021, 05:35
Skruffy's Avatar
Skruffy Skruffy is offline
Nice work Phoenix.
If you haven’t invested in a battery monitor I can’t recommend one strongly enough. Not having one is like not having a fuel gauge. I’ve been using a Trimetric from Bogart engineering for years and years. Helps maintain your batteries for extending performance and life. Wiring one in is no more difficult than what you have already done with this project.
I like that 16’ scope too. I imagine that thing comes in handy quite often.
Rate This Thread:
Interesting Concept "Local Motors" WB9YZU Non-Tech / Off Topic 5 December 12th, 2011 09:54
my "interesting" day at work yesterday ladywolf South East Chapter 15 July 30th, 2010 07:46
Interesting occasional "popping" noise in XJ idahjo OEM Tech Discussion 12 January 8th, 2010 20:27
Interesting perspective "King Paulson" Ecomike Political Discussion Zone 0 November 18th, 2008 22:50
some "interesting" idle xjfreak40 OEM Tech Discussion 3 January 7th, 2008 21:53
