Old October 10th, 2021, 11:21
azzy89 azzy89 is offline
Booster Upgrade
Originally Posted by giacomo.m View Post
I also saw that there is another white switch on the brake pedal, on the top what is its function ?
could it possibly be used for the rear stop lights ?
Giacomo
That switch should be your torque converter lock up switch, some people have used them for brake lights as well. For mine, when doing the WJ master and booster swap, I really had to mess with that switch to get it to function 100% of the time. I had to leave the bolt on the pedal a little loose and had to double nut it. Take care if using the torque converter lock up switch.
Old October 10th, 2021, 11:24
Booster Upgrade
Hi all,
as already mentioned, the swap has brought about a 100% improvement in braking (even if in the first part of the brake pedal stroke there is no effect) but now I no longer have the rear brake lights ...
brake light switch or an adjustment problem of the same on the brake booster rod ?
thank you
Giacomo
How close did you get the booster rod to match the original? Pics? Did you measure it with a caliper to see if the distance from center to outside of the flat part is the same? Iíll get a picture of how I set up mine.
Old October 10th, 2021, 13:20
giacomo.m giacomo.m is offline
Re: Booster Upgrade
Thank you azzy89
I will try to loosen the brake pedal bolt, and what problem could happen if i used the white switch for the brakes lights ?
Giacomo
Old October 11th, 2021, 00:58
Booster Upgrade
Thank you azzy89
Giacomo
Well if something gets wired wrong you could potentially fry your TCU. But if you use it just as a switch it should work fine. Also keep in mind the brake switch is replaceable, I believe the TC switch is JY only.
Old October 11th, 2021, 01:01
Booster Upgrade
Hereís an article to check out
https://www.google.com/amp/s/budgetg...light-fix/amp/
Booster upgrade ! PMGaming101 Modified Tech Discussion 10 October 13th, 2014 06:16
Brake upgrade question non-abs booster to abs booster 94xjstud Modified Tech Discussion 3 February 3rd, 2010 10:12
99 Brake Booster Upgrade!!!! AZRockRunner Arizona Chapter 0 May 8th, 2007 21:47
WJ brake/booster upgrade,.. bxj Modified Tech Discussion 0 August 25th, 2006 22:11
Upgrade to 95 booster,M/C redwagon Modified Tech Discussion 8 September 17th, 2003 17:50
