Old February 15th, 2015, 09:49
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
P0112, 2000 Classic. This is driving me nuts
I have replaced the IAT, I cant find any vacuum leaks. The Jeep runs great. I can reset the code and it will come back on within a day or so.
Any ideas????
Old February 15th, 2015, 10:32
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: P0112, 2000 Classic. This is driving me nuts
Checked for wiring and connector issues ?
P0112 Jeep - Intake Air Temperature Sensor 1 Circuit Low
Possible causes
- Faulty Intake Air Temperature (IAT) sensor
- Dirty air filter
- Intake Air Temperature (IAT) sensor wire harness is open or shorted
- Intake Air Temperature (IAT) sensor circuit poor electrical connection
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old February 15th, 2015, 17:39
Sensor is new, filter is good. No obstructions in the tube. What voltage am I looking for at the sensor?
Old February 16th, 2015, 16:37
Tim_MN's Avatar
Genuine Jeep IAT sensor or some crappy Chinese "Lifetime Warranty" junk ?
Old February 16th, 2015, 19:55
Whatever Oreillys sells :-(
Old February 17th, 2015, 11:30
Tim_MN's Avatar
Crappy Chinese junk. :-(
Always use genuine Jeep sensors, cheapo parts are cheap for a reason.
Old February 18th, 2015, 03:27
Tried three sensors. Same result. Cheap Chinese junk or not one out if three should be close. Any other suggestions
Old February 18th, 2015, 09:17
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Yeah, stop throwing parts at it and do some actual diagnosis. Turn the ignition key on, check for 5.0 volts on the sensor supply side, check that first. Sensor return side is normally from 1 to 4 volts with the sensor connected. Next, disconnect the battery, disconnect the sensor and the pcm connectors, check the sensor return wire for a short to ground with an ohm meter. If that checks out ok with no short to ground, put everything back together. Next step is figure out when does the code set? Immediately or after driving. How are the engine mounts? An engine with bad mounts moves and causes wiring problems. Circuit low faults are generally a short to ground between the sensor and computer on the signal return side. Inspect the wire harness from the sensor all the way to the computer. Look at the sensor and note the colors of the wires, start opening up the harness sheathing and follow the wires. If necessary, run new wires from the pcm to the sensor and see if the code resets.
Old February 18th, 2015, 17:30
Bryan, all due respect I normally dont just throw parts at a issue. This is my moms XJ and it rarely sits still long enough for me to really do some diagnosing. Not to mention its friggin cold here in VA right now.
I will get her to drop it off long enough for me to track down the wiring and see what I can find
Old February 19th, 2015, 09:07
Bryan C.'s Avatar
Haha, sorry if that come off in a bad way. I should have used a smiley somewhere. Anyway, at least it won't leave your Mom stranded anywhere.
I need help - this is driving me nuts... boostleak NorthWest Chapter 13 May 17th, 2009 23:44
Classic Wheels from 2000/2001 Cherokee Classic/Limited. bill99hawk Wanted: Private Party Only 0 July 6th, 2006 17:38
Classic Wheels from 2000/2001 Cherokee Classic/Limited. bill99hawk For Sale: Private Party Only. XJ ITEMS ONLY 0 July 6th, 2006 17:35
This is driving me nuts... mdl Non-Tech / Off Topic 15 April 8th, 2006 16:46
PM driving me nuts!! Redcbr007 User Support, Questions and Suggestions 0 April 25th, 2004 10:53
