Old February 9th, 2014, 03:28
a_ibrahem a_ibrahem is offline
2000 XJ TPS issue
Hello everybody ,
am new here to the forum and to the XJ also ,
i have 2000 I6 AT XJ ,
it has P0123 code ,
my XJ has one socket to the TPS with 3 wires
as i understand the wires are :
1- TPS ground
2- TPS signal to PCM
3- 5 volts from PCM
i unpluged the connector to the TPS sensor and measured with the fluke while ignetion key in ON position
i have 5 volts on wire 2 and 3
my question : wire 2 is signal from TPS to PCM so why there is 5V on the wire all time ??
please advise.
Old February 9th, 2014, 08:22
Digger87xj's Avatar
Digger87xj Digger87xj is offline
Re: 2000 XJ TPS issue
Its normal. It is a carrier voltage.
Old February 9th, 2014, 13:55
ok after reading some of the threads ,I went down and measured the voltages again
1- TPS ground
2- TPS signal to PCM showing 5.6 volts
3- 5 volts from PCM showing 5.1 volts
code p0123 and not clearing also
then as many mentioned I removed the horn relay and measured again
1- TPS ground
2- TPS signal to PCM showing 4.6
and now when clearing the codes with scan tool its gone
so what is the issue with that horn relay ,am not able to find how its interlinked ?
Old February 9th, 2014, 14:58
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Typically a P0123 is a TPS fault. If removing the horn relay prevents the Trouble Code from reappearing, you have clock spring or steering column wire harness issue. The horn and the TPS share a ground connection. If a short circuit involves the ground wire, you have high voltage on the TPS.
P0123 Jeep - Throttle Position Sensor Circuit, High Input
Possible causes
- Faulty throttle position sensor
- Throttle position sensor harness is open or shorted
- Throttle position sensor circuit poor electrical connection
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old February 10th, 2014, 00:15
hello guys ,
thanks for your support ,yes removing the relay cleared the codes and also it stops hesitating while accelerating. it runs very smooth now
how can i diagnose more the problem ?
how to make sure its the clock spring before buying new one ?
and if its just that they share ground if i separate them (if it’s possible) will this solve the issue ?
regards,
Ahmed
Old February 10th, 2014, 18:43
Tim_MN's Avatar
Unplug the clock spring and plug the relay back in. If the problems does not return, the clock spring should be tested for failure.
2000 xj Window Issue Trixie03 OEM Tech Discussion 13 April 22nd, 2013 11:22
2000 Xj classic 4x4 shifting issue seanjohn0226 OEM Tech Discussion 3 January 16th, 2013 18:19
2000 xj fuel issue climbtothebeet OEM Tech Discussion 3 September 20th, 2009 06:43
2000 XJ - stalling issue JeepsterXJ OEM Tech Discussion 6 August 9th, 2009 10:07
2000 XJ D-35 w/ABS Rear End Issue aviationstation OEM Tech Discussion 2 March 31st, 2005 17:23
