Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old July 3rd, 2009, 07:19
16guns 16guns is offline
Opinions Needed
I have a 99 Cherokee with a RC 4.5" lift on 33's. I am running stock 3.55 gears with no lockers. It is my DD and weekend rig. Should I replace the RC lift with a RE 5.5 Long arm for better on and offroad feel or should I get a RC Control Arm Drop kit for $190.00 and put gears and lockers in? I have Rock Rail's and unibody reinforcements on already I have a limited budget and not quite sure which way to go. Any input would be appreciated.
Old July 3rd, 2009, 07:56
Jamescad04's Avatar
Jamescad04 Jamescad04 is offline
Re: Opinions Needed
Personally I would keep it where you are at! That's where I'm gonna be in a month or so hopefully.
Old July 3rd, 2009, 09:07
Re: Opinions Needed
So just go with gears and selectable lockers? My director of finance (wife) puts a choke hold on my spending from time to time. Otherwise I would do it all. So are you anti drop brackets?
Old July 3rd, 2009, 12:29
Jamescad04's Avatar
Re: Opinions Needed
If it is going to continue to be your daily driver I wouldn't put a locker in it! Just my personal opinion I'm sure there are a lot of people that would disagree with me.
So are you anti drop brackets? <--- What do you mean? Where did this come from?
Old July 3rd, 2009, 10:29
bigalpha's Avatar
bigalpha bigalpha is offline
Oh the huge manatee
Re: Opinions Needed
Go with gears and lockers. Those two things will get you through more places than long arms will.
1992 XJ, 4.0, AW4, D30/D35
Old July 3rd, 2009, 10:44
Re: Opinions Needed
That is the way I was leaning but since I am a noob ...I figured I'd ask. Thanks for your help.
Old July 3rd, 2009, 12:41
bigalpha's Avatar
Oh the huge manatee
Re: Opinions Needed
Why would you not put in selectable lockers?
Old July 3rd, 2009, 13:03
Jamescad04's Avatar
Re: Opinions Needed
Never Been a fan of Lockers especially on road! Ive never been in a situation either that I couldn't get out of with my 4 wheel and a winch!
Old July 3rd, 2009, 12:42
muddyrocks muddyrocks is offline
Re: Opinions Needed
Cuz Detroits rule.
Old July 3rd, 2009, 13:12
bigalpha's Avatar
Oh the huge manatee
Re: Opinions Needed
What's wrong with running a selectable locker on-road? It'll act like an open diff until you activate it. Plus, why get out and use a winch when you can just activate your lockers and get out of the same place?
I'm just lazy, though.
Old July 3rd, 2009, 13:18
Re: Opinions Needed
I was asking if you were anti drop brackets because you mentioned to keep it where it was and I thought you might be anti drop brackets for some reason and I am trying to look at all angles.
Old July 3rd, 2009, 15:38
mbogosia's Avatar
mbogosia mbogosia is offline
Re: Opinions Needed
Eric(trailratethis) has drop brackets and he gets awesome flex. I say go with at least one locker and get it geared. I would get the gears so they will work good with 35's as well because it is only a matter of time.
Old July 3rd, 2009, 22:18
Swamprat Swamprat is offline
Re: Opinions Needed
you could buy my junk wheel the crap out of it, and keep you DD as is
Old July 4th, 2009, 00:00
kj139's Avatar
kj139 kj139 is offline
Re: Opinions Needed
Keep your current lift and get gears and lockers. I have a 5.5" T&T Y-Link lift with great flex, 4.56's and ARB's. The gears and lockers make waaaay more difference than the flex. I just got back from the Rubicon and the rigs with lockers had a much easier time than lifted rigs without. One of the guys in our group had a killer Landcruiser with a 350, 35's and a lift (spring over). He struggled in a lot of places that we just walked through simply because his wheels weren't turning.
I've installed gears and lockers for lots of friends and one thing always holds true: They wish they had gone one gear size lower (numerically higher). Everyone gets locked into this "my mileage will suck on the highway" mentality, which simply isn't the case. In fact, with taller gears, your mileage will be terrible around town and on hills, since it takes more for the rig to get take off. I found this out the hard way. My point is go with one size lower than you think you need.
As for the lockers...I put in Detroit Trutracs in two friends' YJ's and they are awesome. You can get them for about $400 each, they are un-noticeable on the highway (even in the ice) and they lock up great when wheeling. I love my ARB's, but for the price, I think the Trutracs are the way to go (not to be confused with lunchbox-style lockers that replace the spider gears; these are a well-built, full carrier).
Anyway, my two cents...Good luck!
Old October 29th, 2011, 12:12
Slonopotam's Avatar
Slonopotam Slonopotam is offline
NAXJA Member #1358
Re: Opinions Needed
Except that truetracks are not lockers. They are torque-sensitive limited slips. One wheel in the air - the other gets no torque. I have them both in front and in the rear.
Rate This Thread:
opinions needed motoman Red River Chapter 29 April 20th, 2009 11:00
opinions needed homebrew SoCal Chapter 9 September 9th, 2006 00:07
opinions needed az4wheeler2002 Modified Tech Discussion 63 November 22nd, 2005 19:44
Opinions Needed Rocketman Modified Tech Discussion 19 January 30th, 2005 06:08
Q's about 8.8, opinions needed lisdexic Modified Tech Discussion 1 January 11th, 2005 18:38
