pictures are self explanitory... I got the idea somewhere on line(maybe from here.) but can't remember where.. anyway.. thanks to them.
the rack is my own twisted creation.. it has shelves and a pull out drawer.. I hadn't installed them when I took this pic.
I got the two compressors from a U Pull it for $10 dollars a piece. They came out of late 80's early 90's caddilacs. I added a check valve to also.. it's the brass fitting on the end of the tank. the lines from the compressors are high pressure fuel line and a pvc tee. I still need to find a CHEAP adjustable pressure switch.. right now I only bring it up to 75 psi...and turn it off with the switch.
Notice the cool spongebob accessories.. courtousy of fathers day Switches for electric fan and compressors. I used a relay with the switch.
Notice Cool welding job on my rack for the back... NOTE TO SELF.. NEVER WELD ON Galvanized steel again..
