Does anyone know where you can get the tool that allows you to install a rubber valve while the tire is still on the rim without the tire bead having to be broken down?
It may be something that the military developed or someone else.
I know that I can break the tire down but with beadlocks it would be alot easier and with a valve stem that has a slow leak etc it would be easier to install a valve from the outside instead of breaking the bead and coming from the inside.
Thanks
GRNT
Thanks
GRNT
