whitneyj
- Mayville, WI
I'm plating my rails, after spending 1/2 a day getting the LCA and trackbar mounts off, and wasn't sure about how to plate the rear of my XJ. Do people remove the rear spring hangers and plate the rails then re-attach the mounts? or just leave the mounts and weld the reinforcements to it? I understand that when plating the unibody you don't want vertical seams, you want to angle them to avoid cracking there. help?
