Old April 16th, 2018, 15:04
RCP Phx RCP Phx is offline
What's the wiring for my CEL(2000)
Tried to take it to emissions today and lights not working. Haven't checked the bulb yet, but what drives it?
Old April 16th, 2018, 15:10
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: What's the wiring for my CEL(2000)
The OBD-II CEL should illuminate briefly everytime when you first turn the ignition key, and hear the four beeps from the cluster. This is most likely driven by the ECM as a self test. CEL should also illuminate when you activate the instrument cluster self test routine.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old April 16th, 2018, 15:44
The light is required to illuminate to pass emissions!
Old April 16th, 2018, 18:17
It's part of the instrument cluster. It's already repaired by stealing my ABS lamp(which I don't have). Now where to you find replacement lamps, is the body part of it?
Old April 16th, 2018, 18:28
Found it, it's a PC194 !
Wiring Gurus: Help! 1988 Header Panel on 2000 Wiring Mtb Jak Modified Tech Discussion 12 April 14th, 2011 06:21
91 and 2000 wiring white91 Modified Tech Discussion 20 September 27th, 2010 17:01
WTB: wiring harness for 2000 XJ altierior SEC For Sale / Wanted Forum 7 September 1st, 2010 17:31
OHC wiring help please 98 to 2000 kenallwine OEM Tech Discussion 5 September 23rd, 2009 11:13
