Ok so this was the test run on my revamped suspension, I went to 4.5 rubicon springs, swapped in a d30 hp and rear d44 among other things. Right away there was loud banging and popping from the front left,quick look and found it was the spring rubbing and catching on the IRO track bar mount,no biggie grind it down later,then I checked again and noticed the driveline is rubbing on the header, ok grind down the corner on the header no biggie. But got to thinking are the two problems connected? I set the track bar to what IRO recommends and my axle is straight (even side to side). I think I took this pic with the passenger side tucked up and driver side drooping,I think.Also will this contact **** up my yoke bearing?What do you guys think.2000 auto 4.5" hp30 d44 zip lockers and stuff
