Old March 10th, 2018, 17:22
Jeff-97XJ's Avatar
Jeff-97XJ Jeff-97XJ is offline
Brake Lights On?
I just got to the Jeep and noticed the brake lights were on. Very
Strange as I parked it a couple of hours ago. Jeep started
Fine but noticed voltage meter was on 13 and it is usually on 14.
I got to where I was going after driving about 30 minutes.
I turned the Jeep off and all 3 brake lights are still on.
How do I get them to
Go off?
Thanks in advance.
Old March 10th, 2018, 17:31
emx721 emx721 is offline
Re: Brake Lights On?
Had the same issue on my 99, it was the brake switch on top of the brake pedal. Play with your brake pedal and see if it goes away.
Old March 11th, 2018, 17:34
Jeff-97XJ's Avatar
Thank you for the tip, it worked and the brake lights went out.
Do you know if there is a way to lubricate the switch so that this doesn't happen again?
Thanks-
Old March 11th, 2018, 19:49
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
I have had good luck using WD-40 (or something similiar) with sticking switches such as this. It's non-conductive so it won't short circuit the switch.
Old March 11th, 2018, 23:38
ADlBOO ADlBOO is offline
Brake Lights On?
You might also need to reset the switch. If somehow the brake pedal got pulled backwards past its normal stop it could've moved the switchs resting position so now the pedal won't contact it when it returns to its normal resting spot.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old March 12th, 2018, 12:46
Thanks-
I don't know about lubricating the switch (I never tried), but it's a cheap part and not so hard to replace (and I have 2 left hands, lol). I purchased original mopar and it was USA made. You need mopar 4671336AD , It can be had for less than $17 or aftermarket for even less.
If you need FSM instructions let me know.
Old March 12th, 2018, 12:48
Also If it happened once it might happen again and I wouldn't risk draining the battery.
Old March 12th, 2018, 12:50
https://www.ebay.com/itm/Mopar-46713...dX15RK&vxp=mtr
no brake lights, turn signals or dash lights bmxdude151 OEM Tech Discussion 6 September 9th, 2013 07:51
No marker lights, no brake lights, no dash lights twodoorXJ OEM Tech Discussion 5 December 16th, 2012 08:35
Brake lights work but dont when tail lights are on ptf18 OEM Tech Discussion 4 January 14th, 2010 17:05
No reverse lights or brake lights or turn signals... TheHighHeat OEM Tech Discussion 6 October 5th, 2008 15:13
