Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Comanche MJ (1985 - 1992)
Jeep Comanche MJ (1985 - 1992) Jeep's Cherokee-based compact pickup technical forum.
Old December 2nd, 2021, 16:55
DrSockMonkey's Avatar
DrSockMonkey DrSockMonkey is offline
Alternative spring packs for big lift.
I have an 86 MJ long bed with a SOA Dana 60 rear and running 37's. The current configuration is unknown spring packs, 4" blocks and 2" shackles. I want to get rid of the block, or as much block as possible. I also would like to add 2" of lift to the rear as it's 2.5" lower than the front. From center of front axle to bottom of stock fender flare is 31", the rear spacing is 28.5". Happy to hear of vendors who sells packs too. I have done searching but MJ's use different packs than XJ's so I didn't see a lot. Thanks in advance for any help.
Old December 4th, 2021, 13:24
smokeyyank smokeyyank is offline
Re: Alternative spring packs for big lift.
General spring, deaver and Alcan all make packs . Alcan and deaver can make custom packs.
Old December 5th, 2021, 08:41
That's perfect. Thank you, smokeyyank.
Old December 6th, 2021, 12:22
No worries, check out comancheclub.com for more MJ stuff.
Old December 7th, 2021, 10:59
Copy that, thank you.
Old March 6th, 2022, 22:03
RickDT RickDT is offline
Great to hear Alcan is also recommended here. We'll work on my friend's new MJ project after we finish installing suspension, jeep bumpers, and winch on the Wrangler this week.
Alternative leaf spring bushings? QuiGonGene Modified Tech Discussion 1 September 16th, 2016 06:08
WTB - 2" lift rear spring packs 01yellowxj SEC For Sale / Wanted Forum 0 August 25th, 2012 19:44
6-7" lift leaf spring packs needed 85xjwoody MWC For Sale/Wanted Forum 3 June 21st, 2008 07:28
Spring Packs xjjeepman Modified Tech Discussion 0 April 28th, 2005 03:03
Help I installed a RE 3.5" Lift with rear spring packs now I have vibrations Augidogi Modified Tech Discussion 2 May 3rd, 2003 23:20
