Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Non-Tech / Off Topic
Non-Tech / Off Topic The popular Non-Tech Forum. NO SPAM at all. Period.
Old February 12th, 2006, 18:02
BSD's Avatar
BSD BSD is offline
Rebuild a Manual transmission?
Hre's the deal. My oldest son is getting ready to drive. I found a Nissan d-20 89 pickup 2wd 5 spd. Basic. In great condition. However, the synchronzer is going out in 1st gear. On a scale of 1-10, how hard is it to re-build a manual transmission on your own? I ask because it will determine if I buy it. It is a good deal but it loses it's appeal if I have to spend close to a grand to get it re-built.
Thanks
BSD
Old February 12th, 2006, 20:13
bajacalal bajacalal is offline
Re: Rebuild a Manual transmission?
Is the 1st gear even synchronized??? Usually grinding when entering 1st (and R) but not between the other gears is a sign of incomplete clutch disengagement- bad master or slave hydraulic cylinder or clutch cable adjustment is out of spec.
Old February 13th, 2006, 03:23
BSD's Avatar
BSD BSD is offline
Yeah, I checked an exploded view and 1st has a synchronozer. It wants to kick it out of first. You have to hold it in first with your hand. Only does it in first.
BSD
Old February 13th, 2006, 06:55
Spudboy's Avatar
Spudboy Spudboy is offline
If he is mechancally inclined at all, he should be able to do it. I started rebuilding '50s vintage Ford 3-speeds at age 14. Graduated to Chevy Powerglides and Muncie 4-speeds. By 16, I was rebuilding MG/Austin Healy 4-speeds, TH-350s, and assorted other stuff. Almost cut my fingers off putting a Buick Dynaflow on a bench once.
Most transmission parts houses will have a manual for that tranny and will be able to get the parts you need. Popping out of gear is a classic symptom of bad input or output shaft bearings. Could be the synchro, or something as simple as the synchro lock plates.
I say let him go for it. Just pay attention to where the small parts came from, especially the shifter detents and lockouts if they are in the case. Worst outcome will be a truck with a bad transmission - still.
Spudboy
Rate This Thread:
Changing the manual transmission oil ... montanaman OEM Tech Discussion 2 January 9th, 2006 18:35
Transmission Rebuild Cost 88XjLaredo OEM Tech Discussion 10 October 24th, 2005 19:58
AX-15 Rebuild, need service manual cyrus OEM Tech Discussion 4 March 28th, 2005 16:46
NP 242 rebuild manual Jeep839 OEM Tech Discussion 3 March 27th, 2005 22:28
Manual Transmission oils Anthropy OEM Tech Discussion 31 August 19th, 2003 07:09
