Georgia Mike
- Flowery Branch,GA
HP Ford 44 (from a 3/4 ton leaf spring truck) or LP 60, both ball joint axles, both with matching 60 rears. If you could only afford one of the two sets, which would you choose?
And I was wrong. I went back and looked, the 60 has kingpins.
you need to settle in on a tire size goal before making a decision. personally on a cherokee 37" tires and under will get you everywhere a full body cherokee can go without major destruction. A well built 44 is very capable IF YOU PUT THE RIGHT PARTS IN IT. a 60 is pretty heavy and ungainly at anything 38" and under, im not a huge fan of 1 ton axles in general. a well built and narrowed 44 under a cherokee will do just fine
Agreed to a point. I'm a one ton fan though. Mike you need to look at tire rim size too. The one ton does not like 15" rims either. You've known me a long time and seen both my rigs I've had over the years in action. If I were to start over I'd very seriously consider a HP D44 waggy width front with alloy or RCV shafts with 37 treps.
You beat me to the whole RCV thing. I am a 1 ton fan myself.
If I ever build another 44 it would be with RCV shafts. Don't bother with regular chromoly shafts unless you like changing joints. I had grande chromoly setup on my last 44 and it would kill the 297 joints with 36s. With RCVs I guess your moving the weak link to the ring and pinion?
Ctm joints are in a whole different durability class and price range than a regular joint.
