Old April 23rd, 2012, 06:50
rkates's Avatar
rkates rkates is offline
Long arms vs mid arms
I'm redoing the front susp. on the jeep and was going to go long(32" lowers) arms but I'm second guessing my plans. So the question is am I going to see any difference between l vs mid? The jeep sees double duty( road and rock)
Not sure if it helps but waggy 44 5.13's Detroit 36"iroks
Thanks for any help
Old April 23rd, 2012, 07:01
foxwar71 foxwar71 is offline
Re: Long arms vs mid arms
The biggest/only difference between long and mid arms is length
Properly setup, they both perform fine and work great. There should be no real noticeable difference.
Old April 23rd, 2012, 07:43
ktm racer 419 ktm racer 419 is offline
midarms work great. i see no real need for anything much longer on an xj. I have more than enough travel and the control arm stays at a decent angle throughout the range of travel (with raised control arm mounts on the axle).
Its easy to build and you don't need to cut into your floor to get decent antisquat numbers (if you care about that). Doesnt interfere with the transmission crossmember area, so you don't have to build around that either.
Its just simple to build and down right works.
Old April 23rd, 2012, 16:55
twodoorXJ twodoorXJ is offline
yeah....what ktmracer said
Old April 23rd, 2012, 17:03
MoparManiac's Avatar
MoparManiac MoparManiac is offline
There are a lot of variables. It was much easier to fit a long arm on my MJ.
Either one would work fine.
Old April 25th, 2012, 19:42
rkates's Avatar
Thanks guys. Looks like I'll be changing some things up then. Mid arms it is
Old December 5th, 2012, 04:48
flyingxj flyingxj is offline
long arms are better for taller jeeps becouse short arms become to vertical and taller hights due to geometry goodluck
Old December 5th, 2012, 07:00
sunburned sunburned is offline
If you are building it all yourself, the choice is simple. Build the arms exactly the length you want to maximize suspension performance and on road handling.
Why would you second guess longarms because of road duty? My 3 link has 32" lowers I believe and rides great on the road.
Old December 6th, 2012, 12:51
DeftwillP's Avatar
DeftwillP DeftwillP is offline
About 7 months late to the party and nobody is talking about short arms.
Old December 6th, 2012, 14:35
highspeed's Avatar
highspeed highspeed is offline
LOL
Old December 6th, 2012, 15:40
souske's Avatar
souske souske is offline
Drop brackets
Old December 6th, 2012, 16:08
cracker's Avatar
cracker cracker is offline
this is about mid arms or long arms....height would not matter in either case (unless it is stupid tall 9"+)
ford 44 radius arms to long arms need ideas BigRedMachine Modified Tech Discussion 2 January 23rd, 2008 18:45
long arms for $600 Shomsky462 Modified Tech Discussion 32 October 6th, 2006 21:04
Short arms, vs. long arms, vs. RE drop drackets Toyman Modified Tech Discussion 20 February 15th, 2006 01:49
one ton long arms? xjrugger Modified Tech Discussion 2 March 28th, 2005 14:19
Long arms and upper control arms. Dann Modified Tech Discussion 22 September 7th, 2003 12:17
