Old October 27th, 2020, 13:14
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Re: Rear Suspension Issues
Originally Posted by NOTNSUV View Post
Ok, shackle box is fine. But I'm finding marks on frame, body each side. Longer or boomerang shackle the fix?
I think it was pointed out that the bolt is running the wrong way? Find where its rubbing and picture a linger shackle, does it still? Boomerangs are nice. Adjustability for where it mounts is nicer! Decide if you are going to use the parts you have would be my recommendation. If so, install it with bolt the right way and go from there. If not, a no lift SRB like sfr is the business for dialing in shackle angle... the HD shackles you had shared look fine to me
97’ XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old October 27th, 2020, 17:46
NOTNSUV's Avatar
NOTNSUV NOTNSUV is offline
You Guys ROCK!
Originally Posted by Evan03 View Post
People think mines lifted like 6" due to front fender height.
In the rear im not running bump stops at all.
I am bumped in the front to keep my track bar out of tge oil pan.
Glad your on track.
Ok, the RE2700 are 5" overall length and will lift the rear 1.25" per RE. Sheesh.. talk about the long way around. Thanks for your patience, can't wait to get them on.
I'm a 'Do-it-Twice' kinda guy.
1999 XJ Sport 4.0L Black
Old October 27th, 2020, 20:56
Evan03 Evan03 is offline
Took me some thinking to figure what srb is. Shackle relocation.
Yes mine are relocated and my shocks are nearly vertical in that position they can actually dampen forces in the direction they come from. Instead of being layed over at an angle.
My shackle angle is good. With a flat spring imagine going down the rd ture drops in a pothole maybe drops 4" in the hole shackle pulls forward shock resists the sudden drop. Offside spring compresses 2" shackle also come forward.
Where am I going with this maybe it is more shackle angle and decent shocks creating the nice ride. Mu rides definitely not harsh or choppy. I do have a slight fear of breaking the main spring leaf as it will drastically negative arch in the twisty stuff. I have notice I have very minimal wheel hop when on the throttle climbing . Washboard rds ride is amazing
Guess my point is idk what my point is
Rear Suspension issues XJwheelman Modified Tech Discussion 7 September 27th, 2013 05:36
suspension issues JoeyBottles Modified Tech Discussion 5 July 25th, 2012 18:46
Front Suspension Issues mavrick Modified Tech Discussion 12 December 23rd, 2010 23:09
Front suspension Issues .... hemiriffic Modified Tech Discussion 4 March 15th, 2010 15:48
Suspension Issues... Grant H. Modified Tech Discussion 8 April 4th, 2007 19:38
