Old September 26th, 2013, 20:45
XJwheelman XJwheelman is offline
Rear Suspension issues
This past winter my brother and I installed some new suspension parts which included a rear 4.5" leaf pack I got from Clayton. After a couple of days my rear end was sagging pretty bad. The leafs didn't have much arch to them. I didn't bother to call Clayton about it because I had already had these springs for 6 months before I installed them. I also figured there wasn't much they could have done. After about a month of trying to figure out what to do I decided to instal an AAL. So I picked up an AAL from Pro Comp and both my brother and I installed it. It leveled out my jeep just right, but I would have been happier if it was slightly higher in the rear to allow for cargo. Either way it helped with the height but now it made the rear ride very rough. It was almost like there was no springs at all the axles where just welded to the body.
One thing I need to add is there is some serious weight in the rear of my jeep which most likely caused the sagging. I keep tools and recovery gear in my trunk and I use the Warn rear bumper and tire carrier with a 33" MTR. The Warn bumper itself weights tons because of the thick steel they used.
Now for what I think is the solution. I currently run the JKS boomerang shackles that add 1" of lift. I would like to instal the HD Off-road No Lift Shackle Relocation with Terra flex 1.5" shackles. My current shackles are completely vertical, if I was to correct the shackle angle and set it to 45 degrees is there any chance that I could loose lift height with the weight of my rear end? Plus I was thinking about changing out the 4.5 leafs for 6.5 leafs, since I'm so heavy in the rear 6.5 leafs may actually net me around 4.5 of lift. What do you guys think.
Old September 26th, 2013, 20:51
Re: Rear Suspension issues
Disregard the second picture. That's before the new suspension parts were installed. I was on 4" with 32"s. I did this post with Tapatalk and I selected the wrong picture.
Old September 26th, 2013, 21:31
crimsondragon crimsondragon is offline
AALs mess with the original spring rate because the leaf itself is of a different spring rate. With that said, a completely vertical shackle would not help matters. Adding the shackle relocation boxes should smooth it out somewhat but with that AAL it will always ride rough. Since you're using their new no lift boxes, which replace the original boxes, and decreasing the shackle angle as well to 45* optimally, you will probably lose some lift, maybe about 1/4".
Old September 26th, 2013, 21:42
So I'm thinking then, since I originally had a 4.5 lead pack and I added a 2" AAL, a 6.5 inch leaf pack would probably work out. Right?
Old September 26th, 2013, 22:47
Outlander560's Avatar
Outlander560 Outlander560 is offline
teraflex 1.5 inch shackles..maybe you run the same rear setup as I do minus that shackle and I have a pretty dam good shackle angle if i do say so.. remember you also reversed your jks boomerangs which probably arent helping.
the cargo weight is the same as well mainly because I 've been driving around with 83 lbs of steel in my trunk for this front bumper for 3 weeks now plus the same tools and 35 mtr. its really up to you... but i hope you decide not to get the 6.5 inch leafs just not needed imho and will give you to much rake with your 1 inch shackles on top of that.
so after that whole load of nonsense i agree with the previous response the add-a-leafs do change the spring rate you were carrying a heavier load in the rear of the vehicle so it was not a bad decision to make. the no lift relocation brackets are shaweet but a picture of your shackle angle currently would be nice if you could post one up
further more you also turned up your rancho 9000xl whatchya ma call its because you wanted a stiffer ride because it felt to spongy maybe dialing them in more would be a good option as well
Old September 26th, 2013, 22:49
You could have texted me... I didn't reverse the boomerangs. They are still on the same way bent towards the rear
Old September 26th, 2013, 22:56
you reversed them a while ago remember when you had your superlift in? i forgot the reason why.
i just wanted to respond to one of your posts.....never done before...making history right now!
Old September 27th, 2013, 05:36
zachandandy zachandandy is offline
I'd remove the aal and install the standard shackle relocators that give you about an inch of lift. If you are still 1" below where you want to be you could add a pair of 1" perch spacers aka zero rate add a leafs. That puts you at the right height with a better ride than before and less $.
suspension issues JoeyBottles Modified Tech Discussion 5 July 25th, 2012 18:46
Front Suspension Issues mavrick Modified Tech Discussion 12 December 23rd, 2010 23:09
Front suspension Issues .... hemiriffic Modified Tech Discussion 4 March 15th, 2010 15:48
'99 Jeep Cherokee Suspension Issues TheHiker OEM Tech Discussion 17 March 4th, 2009 11:17
Suspension Issues... Grant H. Modified Tech Discussion 8 April 4th, 2007 19:38
