weird idle/something else weird.
gijosiahh
Richmond VA
So lately the jeep has been idling low/weird. i can deal with that. but while its idling low (when im at a complete stop) and i push on the gas it kind of hesitates to go. i can also kind of deal with that. i've actually gotten advice on that a while back, so thats not my question. Whats also happened a few times is i'll be idling low, and when i go to step on the gas nothing happens...the rpms might fluctuate a little bit,if at all, but the jeep doesnt move...like theres no gas getting to the engine...it happened today at a stop sign and i'm worried this will keep up and screw me over at a stop light or something. haha. what could be the cause of this? thanks for any help
2001 AW4
have you checked you throttle body they have been known to carbon up and block the i.a.c. motor and that could also slow your throttle responce. you should also check the m.a.p. sensor or the mass air sensor. you can get a cleaner for all of them
X2
i'd check/clean/replace your TPS and IAC. I just replaced both on my 2000XJ, and it make a world of difference for idle and throttle response.
