Old July 12th, 2008, 11:50
Begster's Avatar
Begster Begster is offline
Dana 44 Gear Pattern Check Please
Hey all, I was just hoping that some of the gear guru's would just take a look at this pattern for me.
HP44
Backlash: 0.007" (spec: 0.006-0.010")
Pinion bearing preload 0.016" (spec: 0.014"-0.019")
Drive:
Coast:
Old July 12th, 2008, 11:53
poorboy_616's Avatar
poorboy_616 poorboy_616 is offline
Re: Dana 44 Gear Pattern Check Please
Looks Great!!! Perfect centers on all counts. Nice Job!!
No go just break em in nice and easy.....
Old July 12th, 2008, 11:57
Frank Z Frank Z is offline
Whats the backlash reading?
Old July 12th, 2008, 11:58
Begster's Avatar
0.007"
I know its a little tight, I might add a 0.003" shim to the non ring gear side, and see how that works
Old July 12th, 2008, 12:16
waxer's Avatar
waxer waxer is offline
Backlash is fine... leave it and run it like that. Very nice!
Old July 12th, 2008, 16:58
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
Looks mucho bueno! Run it easy for 500 miles and you are cookin wit crisco!
Old July 12th, 2008, 18:08
asp's Avatar
asp asp is offline
x 2165432106479
looks pretty good. i'd call it a day and drive gently.
Old July 12th, 2008, 20:37
Begster's Avatar
Awesome thanks guys, thats what I wanted to hear. Now to take it all apart again and press on the bearings.
asp387 - I recognize that rock in your picture.
Old July 12th, 2008, 20:40
waxer's Avatar
Expect minor variation if the new bearings aren't of the same brand.
BTDT
Old July 12th, 2008, 20:56
asp's Avatar
asp asp is offline
the picture makes the line look more impressive than it really is it's at the gutter...
good luck with the last part.
Old July 12th, 2008, 20:58
I'd suggest tightening up the backlash a bit since your using setup bearings.
Old July 13th, 2008, 07:38
RCP Phx RCP Phx is offline
Pinion bearing preload 0.016"(spec: 0.014"-0.019")
???Pinion pre-load isnt a dimension,its a rotational resistance measured in in/lbs!
Old July 13th, 2008, 08:14
Begster's Avatar
ha, your right, my bad. Pre-load is 16 inch/pounds. Had been dealing with measuring so much shims and the backlash I got messed up.
Old July 13th, 2008, 15:19
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
Good pattern, How many tries with the pinion depth? My best is one, My worst was 13 tries.
You get damn sick of gears after 13 removals and insertions of the pinion. LOL
Old July 14th, 2008, 07:08
Durango-Bob Durango-Bob is offline
13 tries!!! That's kinda amazing. I usually hit it on the 4th or 5th. I start with a shim that's 3/4 of what was in there which is almost always not enough. Then I double it up which is usually too much, but by looking at the pattern I can usually guess pretty close on the next one and then fine tune it one or two times. I also use a slightly higher preload 20 to 25 inch lbs with new bearings since they loosen up pretty quickly.
D30 gear pattern check, first gear install P1atinum Modified Tech Discussion 19 April 7th, 2011 15:19
Check my gear pattern, please Daedalus454 Modified Tech Discussion 7 June 6th, 2008 13:24
Gear guru's...gear pattern check... freerider15 Modified Tech Discussion 21 November 21st, 2007 19:21
Gear pattern check ponyracer1 Modified Tech Discussion 6 February 27th, 2007 22:24
Gear pattern check please, 8.25 jmeeker Modified Tech Discussion 3 April 17th, 2006 06:00
