Old June 13th, 2007, 12:18
IntrepidXJ's Avatar
IntrepidXJ IntrepidXJ is offline
NAXJA Member #647
HP D30 Pattern Check
Here's where I stopped at last night. Give me your opinions. This rig will see a lot of on-road and off-road driving.
backlash is .008
more pictures here if you need them, but some are blurry:
http://myxj.net/g2/v/2000_Build/axles/d30pattern/
I'm thinking the pinion might be a tad too close.....what you think?
Old June 13th, 2007, 12:53
traitor5150's Avatar
traitor5150 traitor5150 is offline
Re: HP D30 Pattern Check
That will work fine run it.
Old June 13th, 2007, 12:55
Hellbent's Avatar
Hellbent Hellbent is offline
looks pretty close to perfect. good job!
Old June 13th, 2007, 13:01
RyanM's Avatar
RyanM RyanM is offline
Gear change or you blew the old set?
Old June 13th, 2007, 13:06
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
You're right the pinion is a little on the close side but it's not enough to be worth the trouble of changing it.
Old June 13th, 2007, 13:07
IntrepidXJ's Avatar
NAXJA Member #647
gear change in my 2000.......going to 32's and switching from 3.55's to 4.56's
Old June 13th, 2007, 13:08
IntrepidXJ's Avatar
NAXJA Member #647
yeah, that's kinda the way I was leaning.......but i can be a little too anal about these things sometimes.
Old June 13th, 2007, 13:10
steelmen's Avatar
steelmen steelmen is offline
looks good to me
Old June 13th, 2007, 13:13
MudDawg's Avatar
MudDawg MudDawg is offline
NAXJA Member #728
Looks about identical to the last 30 I set up....runs nice and quiet too. run it.
Old June 13th, 2007, 13:19
Stumpalump Stumpalump is offline
On a Time Out
Setting a ring and pinion is like doing body work. You can sand and fill and look and sand and fill forever but at some point you have to say I'm done.
Old June 13th, 2007, 15:46
Gaius's Avatar
Gaius Gaius is offline
It's sitting a little deep, but still runnable for a front.
Old June 13th, 2007, 20:17
RCP Phx RCP Phx is offline
The pattern doesnt look bad as shown,but what I dont like is the backlash.I think thats way to loose for a D30.Maybe Rawbrown will chip in with some comments!
Old June 13th, 2007, 20:23
IntrepidXJ's Avatar
NAXJA Member #647
.006 - .010 is spec......i shot for the middle........why do you think it's too loose?
Old June 13th, 2007, 20:28
Specs are just targets,not really developed for HP but the long run(who cares in a stock vehicle).The gears will open up as they break in,I always shoot for .004"-.006" on a D30.
Old June 13th, 2007, 20:50
Gaius's Avatar
I shoot for .006. You want on the tight side when gears are new. Like RCP Phx said the backlash will open up after it's broken in. But .008 isn't bad. Again, this is on the front so it's not important for it to be "perfect".
HELP!gear pattern check 99xjache Modified Tech Discussion 8 January 25th, 2007 20:57
Gear pattern check please, 8.25 jmeeker Modified Tech Discussion 3 April 17th, 2006 06:00
pattern check please massxj Modified Tech Discussion 7 May 16th, 2005 21:05
Pattern check please Root Moose Modified Tech Discussion 5 November 24th, 2004 12:29
Please Check my D30 Pattern ChuckD Modified Tech Discussion 20 March 22nd, 2004 20:08
