Old July 19th, 2012, 18:03
Vanimal's Avatar
Vanimal Vanimal is offline
d44 pattern check
looking for an opinion on this pattern. rear lp dana 44
my first try at gears. want a second opinion before i eff with it much more.
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
Old July 19th, 2012, 18:40
Vanimal's Avatar
Re: d44 pattern check
looks like i was understanding the chart wrong, it looks like it needs some shim.
Old July 19th, 2012, 19:44
Peteyg Peteyg is offline
Way off. What's the backspace? Looks like bad pinion depth to me.
Old July 19th, 2012, 19:48
IH392 IH392 is offline
Need to go way deeper. I would definitely add at least .010 more shim to it. The pattern needs to look like an oval. You only have a half oval. The oval needs to go deeper into the gear than it will look more normal.
Old July 19th, 2012, 19:50
Vanimal's Avatar
yea the pictures i had gave no explanation, so i thought the pattern had to be centered from the id to the od. like i said, first install
i found another pattern chart that explained it better and i'm working on it.
Old July 19th, 2012, 20:28
DoWorkXJ's Avatar
DoWorkXJ DoWorkXJ is offline
4lo&Go
Try adjusting the carrier shims.
Empire Offroad
Old July 19th, 2012, 20:45
Frank Z Frank Z is offline
No, the pinion is not deep enough.
Old July 19th, 2012, 20:48
Porch951 Porch951 is offline
This is what i misunderstood when i first did gears.
Carrier shims are ONLY for adjusting preload (and naturally you need the right amount to make sure the carrier fits tightly in the diff).
The pinion is where you make adjustments. You only make adjustments to the carrier to make up for the changes you made to the pinion.
Old July 19th, 2012, 20:50
Vanimal's Avatar
backlash is at about .007 right now.
messed with it some more, but it's too late to use the impact so i'm waiting till tomorrow to finish. here's where it's at right now.
4 lower teeth in this pic
Old July 19th, 2012, 20:51
Vanimal's Avatar
yea, i try keeping the backlash in spec when checking it, but i only adjust the pinion depth for checking the pattern.
Old July 19th, 2012, 20:52
Vanimal's Avatar
i'm going to run out to try to take some clearer pics, it's dark out so not so easy
Old July 19th, 2012, 20:55
DoWorkXJ's Avatar
4lo&Go
I do my own gears I know. I'm just saying to compensate for the pinion adjustments to adjust his carrier shimming from side to side as well.
Empire Offroad
Old July 19th, 2012, 21:03
Vanimal's Avatar
ok used the real camera this time.
teeth with the most yellow on them
Old July 19th, 2012, 21:05
DoWorkXJ's Avatar
4lo&Go
It's a lot better. Can you get it deeper?
Empire Offroad
Old July 19th, 2012, 21:06
Carrier shims set preload and backlash.
D30 Pattern check menos Modified Tech Discussion 30 January 27th, 2012 16:36
D44 Pattern Check Please racer32 Modified Tech Discussion 8 April 20th, 2008 00:27
pattern check please massxj Modified Tech Discussion 7 May 16th, 2005 21:05
Pattern check please Root Moose Modified Tech Discussion 5 November 24th, 2004 12:29
Please Check my D30 Pattern ChuckD Modified Tech Discussion 20 March 22nd, 2004 20:08
