Old January 29th, 2005, 12:53
darkspeed's Avatar
darkspeed darkspeed is offline
Unhappy bad running , fuel pump check => no start
Hello,
I'm french, so first, sorry for my english...
I'm tring to solve a problem on my 88 4.0L XJ:
While the cars runs fine (at 50/60MPH), it has some "holes" at stabilized speed... but not on rought acceleration or even "off pedal foot"...
This car has an old alarm+cutoff, from precedent owner, I will remove it (perhaps it's the problem)
I begin to think about a faulty fuel pump, I have removed fuel tank, cleaned it (but was fine), check the pump, it seems to be fine also... so I replace it back... And the card doesn't start now :-( ...
When I turn to ignitition position, I hear the pump doing a small noise for 3 or 4 seconds, and same noise while I trying to start engine. The engine runs but doesn't start :
- I have checked at the valve on the injection ramp and there's some fuel (without any pressure).
- I have about 7 Volts at the pump plugs.
Tomorow I will try to :
-Remove the fuel filter (who has 3000Miles), and check if the pump give some fuel...
-Remove a plug and check for spark.
-Remove the old cut-off/alarm.
Anyone could give me some indications about finding the real problem ?
I'm from france and NOBODY here really knows the 4.0L XJ (only the 2.1 Diesel here...) so I cannot bring it somewhere to repair (it's an exotic car here...) and finding spares is a pity (could you find some Renault Megane parts in USA ?).
Thanks a lot for ANY advice.
Old January 29th, 2005, 13:06
old_man's Avatar
old_man old_man is offline
Re: bad running , fuel pump check => no start
Are you saying that the engine runs rough at 50mph, but not under accelleration and decelleration?
The symptoms you describe do not lead me to believe that the fuel pump or fuel system is the problem. 7volts at run is about right and it should run for 3-7 seconds after you turn on the ignition.
It seems more likely that the MAP sensor or throttle position sensor is the problem. The symptoms do not lead me to believe that the crankshaft position sensor is bad. They normally either work or do not work.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old January 30th, 2005, 01:32
darkspeed's Avatar
Unhappy Re: bad running , fuel pump check => no start
Thanks for advice :-)
I'll be checking this also... This morning I'll begin to :
- test fuel circuit (to see If I haven't do any mistake).
- Check Spark
- remove the old "cutoff/alarm"
Thanks for replies :-)
Old January 30th, 2005, 08:31
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
I think your year has a balast resistor: it will be located on the left hand side inside the engine compartment towards the back: it is a big resistor (rectangular in shape) that controls the voltage going to the pump. Sometimes the connection on it goes bad and you have to clean the contacts to make it work.
Bad Fuel Pump?? Majo OEM Tech Discussion 2 November 9th, 2004 13:14
External fuel pump...possible? Long. Dragonslayer Jeep Street and Performance 5 October 4th, 2004 20:43
What if... Fuel pump goes out on road/trail???temporary fix? Tim88XJ OEM Tech Discussion 6 July 18th, 2004 13:14
Water Pump failure questions 2xtreme OEM Tech Discussion 2 December 6th, 2003 06:53
Power to fuel pump questions T180081 OEM Tech Discussion 12 May 2nd, 2003 07:44
