OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
#16
Re: Crank but no start. I can hear the fuel pump running.
What is surprising about that?
#17
Test the CPS, and then test the Cam Sensor.
. ![]() . Quote:
#18
If you don't already have one, I recommend you get a volt/ohm meter also!
1 - check all your connections 2 - check for voltage and grounds to the sensors 3 - test the sensors 4 - in the case of the camshaft sensor check the gear for proper engagement/slop/worn teeth |
#19
Changed cps, camshaft position, coil pack. Fuel pressure good. Best i can tell cps is producing voltage its supposed to. Did find the original camshaft sensor magnet was broken out of place when I changed it. Checked ground to body and engine. Not sure what to do next?
#20
Bad new camshaft sensor from Ebay(imagine that). I ended up buying a camshaft synchronizer w/cam position sensor from Rock Auto for $34. I felt that the shaft had some possible play in it so I went that route. Thanks for everyone's help!!
Thread Tools | |
Display Modes | |
Crank, no start; fuel pump not priming? | kujito | OEM Tech Discussion | 29 | July 10th, 2010 11:44 |
Fuel pump help; crank, no start. | kujito | Colorado Chapter | 0 | July 7th, 2010 06:58 |
Should I be able to hear my fuel pump? | BCParker | OEM Tech Discussion | 7 | October 30th, 2005 00:20 |
bad running , fuel pump check => no start | darkspeed | OEM Tech Discussion | 3 | January 30th, 2005 08:31 |
Can hear the fuel pump prime.......(no turn over) | Ghost | OEM Tech Discussion | 6 | November 24th, 2003 12:54 |
