Old September 10th, 2006, 22:06
POSJ POSJ is offline
OverHeating
Has anybody thought of using the Quickair Induction Scoop for cooling on an XJ? I think its designed for a TJ or something but do you think it would work for cooling an XJ if placed on the hood? Or would this create the Positive pressure I was reading about on another thread?
Tyler
*Edit*
Found a link to it:
http://www.ok4wd.com/index.php/catal...duction_scoop/
Old September 10th, 2006, 23:04
CanMan's Avatar
CanMan CanMan is offline
Re: OverHeating
Turn it around backwards like the hood scoops on older Mopar cars.
From '69 Road Runner 6-Pack.
It will help the air flow over the motor, rather than like a cowl induction effect, which may creat negative pressure, from the air flowing through the front, and the air coming from the back.
overheating still evrydayXJ Modified Tech Discussion 17 September 6th, 2006 10:35
overheating ChipsXJ OEM Tech Discussion 14 January 26th, 2006 22:13
overheating off and on mgt Modified Tech Discussion 11 June 30th, 2005 00:05
Overheating jeeperzevanxj OEM Tech Discussion 2 August 31st, 2004 08:12
overheating valleytroll OEM Tech Discussion 15 October 5th, 2003 22:38
