Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
3.5 inch rubi install
I cannot get the goddamn control arms off, any help with this shit is needed
#2
Re: 3.5 inch rubi install
Installed the same lift last Sept.
I actually split open a socket on one of my control arm bolts using a 1/2" breaker bar. I guess your not supposed to stand on them. HA! This was after 2-3 weeks of libral application of pb blaster.I had to use an impact socket with a long 3/4" breaker bar to finally loosen the two LCA bolts on the axle end. Don't forget EAT YOUR WHEATIES!! Good luck! |
#3
breaker bar+ cheater bar+ BFH= success
#4
hahaha... pb blaster, heat, hammer, LOOOoooong wrench, and bottle jack. Piece of cake! (sugar rush helps)
If you can find replacements just blue-tip the nuts and save your back. |
#5
Use PB Blaster, a torch and a breaker bar. Make sure the PB has had time to penetrate and the fumes have evaporated too! I am sure you have already tried this, but you never know.
#6
i went ahead and cut them off , the front of the kit is finally done
#7
nothings easy.. you just jinxed your self to.. haha join the club !
#8
shit
Thread Tools | |
Display Modes | |
4 brand new BDS shocks for 3.5 inch XJ lift | joe88xj | For Sale: Private Party Only. XJ ITEMS ONLY | 3 | December 7th, 2004 19:53 |
RE 3.5 superflex aal owners report in | willysnut | Modified Tech Discussion | 14 | December 15th, 2003 21:41 |
NC: Major parts for a 4-5 inch lift + 5 31" MTRs on 15x8 767s | Scriff | For Sale: Private Party Only. XJ ITEMS ONLY | 12 | December 14th, 2003 19:06 |
RE 3.5 install | Gr8XJ | Modified Tech Discussion | 4 | October 20th, 2003 10:03 |
Prop valve for RUbi discs | jjvande | Modified Tech Discussion | 17 | October 4th, 2003 11:47 |
