Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old January 14th, 2005, 22:40
FUNKYTEE5's Avatar
FUNKYTEE5 FUNKYTEE5 is offline
Talking 1/4 mile times?
Ok, just for kicks! Who has seen a 4.0 XJ turn out some good 1/4 mile times? No strokers, nitrous, or boost! Just a well tuned, naturally aspirated, stock stroke 4 liter. What are some actual e.t's that y'all have seen?
FUNYKTEE5
Old January 15th, 2005, 06:57
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Re: 1/4 mile times?
I ran my XJ in 14.98@93.1 with a modded 4.0 (full bolt-ons & ported head) and weight reduction before I installed the stroker.
My current 14.50 is with the stroker but no weight reduction.
______________________________
Dino's "Mean Green Machine"
1992 XJ Laredo 4-dr - 4.6L I6 HO Stroker - 181k miles - AX15, NP231, D35c, D30
263hp@4900/321lbft@3300-3800, 1/4 mile = 14.50@95.5, 0-60 = 5.8secs
Websites - Jeep 4.0 Performance, 4.6L Stroker Build-Up, Dino's Jeep Tricks
Old January 15th, 2005, 10:37
XJ Saga's Avatar
XJ Saga XJ Saga is offline
Re: 1/4 mile times?
FUNYKTEE5
14.7 with mine, maximum bolt-on's and moderate weight reduction.
Old January 15th, 2005, 16:16
JeepSpeed's Avatar
JeepSpeed JeepSpeed is offline
Re: 1/4 mile times?
Wow, not bad at all. Elaborate on specific mods please. Stock gearing and tires?
Old January 17th, 2005, 19:02
XJ Saga's Avatar
Arrow Re: 1/4 mile times?
JS: list is somewhat lengthy, I would just go to jeepsunlimited and search under the same user name.
XJ Saga...
Old January 17th, 2005, 19:49
JeepSpeed's Avatar
Re: 1/4 mile times?
XJ Saga...
Knew your name was familiar, will do.
Old January 17th, 2005, 19:58
jeepguy97's Avatar
jeepguy97 jeepguy97 is offline
On a Time Out
Re: 1/4 mile times?
15.7 with a 2" lift and 30s, stock gears, cat back exhaust, and all tools not on board as the only weight reduction. I love the look when I pull up to the line "He's gonna race that."
Rate This Thread:
Mile Marker Hub Conversion TLange Modified Tech Discussion 1 March 4th, 2004 12:20
1/4 Elip CW Modified Tech Discussion 5 October 28th, 2003 16:06
1/4 Times XJEEPER04 Jeep Street and Performance 4 September 1st, 2003 09:27
Mile Marker og Warn freewheeling hub? dana44 Modified Tech Discussion 12 July 9th, 2003 11:15
