Old January 4th, 2005, 09:50
tgissel tgissel is offline
Question AX-15 transmission mount
Does anyone know of an aftermarket transmission mount for the ax-15? I have a 92 xj w/ 8" lift, 33" tires and continue to break transmission mounts. Thanks
Old January 4th, 2005, 09:59
Wa Woody's Avatar
Wa Woody Wa Woody is offline
Re: AX-15 transmission mount
Rusty's makes one. http://rustysoffroad.com/Merchant2/m...tego ry_Code=
Good Luck.
Woody
Old January 4th, 2005, 10:40
I may be mistaken but the vehicles list shows 2.5l auto on the year that I would need. Thanks for the tip, I will give them a call.
Old January 4th, 2005, 11:03
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
why are you looking for aftermarket? I tried one from Kragen and changed that one out for an OEM one after a week. The Kragen one doesn't have the "angle" in it that the OEM one does and as a result it messed up my driveline angles.
Old January 4th, 2005, 11:10
I was thinking maybe a poly mount might be stronger, since this will be the 2nd one this year. Thanks
Old January 4th, 2005, 11:28
old_man's Avatar
old_man old_man is offline
If you are going through them that fast, I would check the engine mounts.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old January 4th, 2005, 11:31
Kejtar's Avatar
PostMaster General
As Tom says, check into the engine mounts. The poly mounts will be very noisy.
Old January 4th, 2005, 13:21
Wa Woody's Avatar
I agree with checking the engine mounts first. I installed a poly unit from Rusty's after replacing my engine mounts and had a lot of vibrations. I kept the poly engine mounts and went with a stock (rubber) tranny mount and like the combo. It keeps the motor where it's supposed to be without too much vibration. Good Luck.
Woody
Old January 4th, 2005, 14:40
Thanks for the input. I will check the motor mounts this evening. Thanks
Is this transmission mount? Hobby OEM Tech Discussion 6 September 18th, 2004 22:26
What the heck? Replaced transmission mount, now exhaust bangs crossmember NotMatt OEM Tech Discussion 11 July 22nd, 2004 10:59
WTB : Puegot Transmission Mount SnowyXJ Wanted: Private Party Only 7 May 20th, 2004 19:40
Poly transmission mount = more power? XJVenom Modified Tech Discussion 12 May 18th, 2004 20:04
Transmission Mount Matthew K OEM Tech Discussion 2 January 6th, 2004 10:30
