dphillips
See,what had happened was
- Augusta GA
Getting ready to do the SYE thing on my 2000 xj. Bad vibes after installing RE 3.5" lift. I noticed in most of the forums concerning driveline vibes that most of the concern is with the rear shaft vibrating. Why are the vibes more likely coming from the rear and not so much from the front? If the lift is changing the pinion/drive shaft angles on the rear, wouldn't it also be changing the front angles as well? Should I also be concerned with the front shaft? The RE kit once installed was closer to 5" of lift.
