85xjwoody
- Little Suamico Wi.
Ok. I have done a ton of searching and reading on this the past few days and after reading about fifty threads I am pretty sure I have a rod bearing knock. I would still like some opinions on the knock being a rod bearing.
At startup I have no knock what so ever and oil pressure is at 60. There won't be a knock until it gets up to about 150 in tempurature and is barely audible at idle when I rev the engine to between 2000 and 3000 is where it is most noticeable. When the engine is at temperature, around 180, and oil pressure is between 20 and 30 pounds you can hear it good at idle. But when you rev up the engine it gets extremely loud!! Makes me cringe! I don't have an oil leak anywhere.
I am 95% sure that it isn't the flexplate. Delt with that already when replacing my engine. My oil pressure seems to be fine and temperature stays at 180 always. I never overheated the engine just gave her some pretty high rpm's once or twice. This engine runs excellent even with the bad knock so I don't want to give up on it yet. I have ran the engine in the garage a few times but never on the road since Memorial weekend when it happened.
Friend of mine is on the way to get some plastiguage so I can get started. Any thoughts or opinions are greatly appreciated. I have the carbed 2.5 inline four which is very simular to the inline six. Getting the pan off while in the jeep is not a problem. Let me know if you have any questions. TIA
Kim.
Kim.
