Old December 11th, 2005, 13:37
sflier sflier is offline
Evap Canister Hose Question
I noticed that the rubber hose coming from the fuel tank (actually connected to the metal tube extension running to the tank) to the evaporative canister has rotted in my '94 and came off. I replaced the hose, but I don't know where to connect it to on the canister (there are two spots that look like possibilities). I'm assuming it connects to this connecter on the canister (see attached photo) … the one that looks like it's plugged with a black plug that has a pin-hole opening in it. Is that the right place to connect the host routing to the fuel tank?
http://pg.photos.yahoo.com/ph/sflier...=/4b26&.src=ph
Old December 11th, 2005, 13:39
old_man's Avatar
old_man old_man is offline
Re: Evap Canister Hose Question
Check the little picture of the emissions vacuum wiring that is pasted on the firewall.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old December 11th, 2005, 13:55
I checked the picture on the firewall, but it just shows that it connects to the canister but doesn't show which of the two possible places it connects with. I have the FSM, Haynes and the parts catalog, but none show which of the two stand-offs this connects with. The other choice looks like it may be fresh air intake as it's short and has an 'x' inside it.
Old December 11th, 2005, 22:01
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
I just looked at my 95. The one you show with the arrow is correct.
Power Steering hose replacement martin OEM Tech Discussion 3 September 8th, 2011 15:46
renix mod- question? Ed in North Ga. OEM Tech Discussion 2 August 15th, 2005 16:09
EVERYONE READ! Re: Vacuum canister JKooshTJ OEM Tech Discussion 5 July 17th, 2004 08:23
Radiator Hose anti-chaffe martin OEM Tech Discussion 5 April 14th, 2003 09:39
Fixing leak in transmission cooler hose (I think). basalt51 Sierra Chapter 3 January 30th, 2003 20:00
