OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Radiator hose issue
Hello all.
I have a 98 XJ 2 door with the 4.0. I recently had to replace my radiator due to a puncture and ever since then my upper radiator hose gets sucked flat (collapsed) when the engine cools off. I'm running the same radiator cap I was before this all started and it never pulled the hose flat (even before the original radiator cracked). The cooling system works properly and doesn't loose any coolant. The thermostat has two holes drilled in it, and the electric fans cycle on and off like they should. Any ideas? |
#2
Re: Radiator hose issue
Make sure there is not a obstruction going to the overflow.
#3
Bottom of the jug could be clogged too.
#4
Meant to add that the overflow hose is clear and the tank is clean.
#5
Get a new cap.
#6
Sounds like you guys nailed this one already, gotta be a bad radiator cap, or plugged overflow in the radiator tube, or hose to the overflow bottle damaged, clogged, or clogged nipple on the overflow bottle. I think that covers it all.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber." 34 MPG ![]() ![]() |
#7
The last radiator I put in, the nipple on the filler neck for the overflow was plugged with paint.
#8
my last had a flat spot on that nipple-- caught it before running it, and convinced it to be round again
[URL="http://www.naxja.org/forum/member.php?u=36241"][COLOR=#ff0000]joe_peters[/COLOR][/URL] :Listen to Shorty--he has spoken wisely [URL="http://www.naxja.org/forum/member.php?u=22111"][COLOR=#FF0000]Ecomike[/COLOR][/URL] :Listen to Shorty--he has spoken wisely X2 |
Thread Tools | |
Display Modes | |
Radiator hose | QCXJ8879 | Arizona Chapter | 3 | September 1st, 2011 07:58 |
radiator cap in upper radiator hose? | vjarman | OEM Tech Discussion | 37 | September 4th, 2009 17:13 |
Radiator Spout where hose connects to radiator overflow bottle.. | gregmondro | OEM Tech Discussion | 10 | August 16th, 2009 09:59 |
Radiator leaking... not a hose.. how big a job is it to replace radiator? | tstaples | OEM Tech Discussion | 5 | November 21st, 2007 10:34 |
Radiator Hose | atticus032 | OEM Tech Discussion | 4 | December 16th, 2003 10:15 |
