Old January 26th, 2005, 10:41
dialogue dialogue is offline
Help in Gear Ratio Selection
Vehicle 87, AW4, 242 TC, dana 30 front, dana 44 rear, (tires maximum 235x15 or equivilant 16s) 1" lift, soon to install blueprinted, 4.7 stroker engine.
I am in the process of rebuilding my axels. I am looking for the best gear ratio for a combination of 75% daily street driving, 15% towing, 10% off roading.
It looks like I will have to replace the 3.55 R&P. I will be adding true tracks to the front and rear. What is the best (better) gear ratio for maximum gas mileage, performance and occassional towing?
TIA
Mike
Old January 26th, 2005, 10:59
bgcntry72's Avatar
bgcntry72 bgcntry72 is offline
On a Time Out
Re: Help in Gear Ratio Selection
2" OME lift with Expedition duty leaves, 4.10 gears, and 30x9.5 ATs.
Best bet, by far, IMHO.
Old January 26th, 2005, 11:17
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
With the stroker engine and a maximum tire size if 235/75R15, the stock 3.55 ratio is a good choice to stay with. 3.73s would be the maximum I'd use, and will be more than adequate if you decide to move up to 30s or even 31s for tires.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old January 26th, 2005, 11:46
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Help in Gear Ratio Selection
agreed
i want to re-gear with my 30's but i have the ax-15 with 3.07 gears...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
gear ratio and tires. again thompson97 Modified Tech Discussion 16 June 21st, 2005 22:04
32" tires....What gear ratio? ve6nn Modified Tech Discussion 37 May 3rd, 2005 09:14
Confirm my gear ratio.... YELLAHEEP OEM Tech Discussion 6 August 19th, 2004 16:09
Gear Ratio Help speedn431 Modified Tech Discussion 4 May 14th, 2004 10:48
Looking to adjust my gear ratio BuddhaBudz Modified Tech Discussion 10 April 15th, 2004 20:12
