MudslinginXJ
- Pennsylvania
I took my 92 jeep cherokee (4.0ltr I-6 aw4) for a drive the other day and it stalled on the way home, got it started again, then it stalled after i traveled about 2 feet. I got it towed home and there was no spark so i saw that the ballast resistor was split in half right below the bolt. Replaced that now i get spark, however it has a hard time starting and idles so rough the engine shakes when i do get it started and if i dont keep my foot on the gas it will stall. Checked the distributor cap and its clean as a whistle. Not sure what else to check. Also when it ran for a couple seconds but rough i could smell what seemed to be un-burnt fuel. I went outside and got code 41 with the check engine light trick. Not sure what else to check. Could it be that my fuel filter clogged, or even my injectors clogged? The jeep has sat for awhile and the tank was on E so i put $10 worth in if it helps to figure out whats wrong. Thanks in advance.
