OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
87 closed system to 92 open system radiator conversion
Well my plastic sided 87 Rad has sprung a leak and if I have to replace the rad I may as well switch over to an open system one and get rid of the leaking pressure bottle. I have a pretty good link (has part #s ect)
http://jeep.off-road.com/jeep/articl....jsp?id=257864 I was just wondering if anyone here wanted to put their two cents in. I may go for a 2 core but, I am pretty easy on mine so a single core would probably do the trick just as well. |
#2
Re: 87 closed system to 92 open system radiator conversion
Don't buy the factory bent hoses. I converted my 89 over and the factory hoses that I bought didn't quite make any sense. Just buy regular coolant hose of the proper diameter and route it yourself, it's cheaper.
I got a GDI 3 core for mine when I did it. Worked great, never had any heating problems after that!! |
#3
two cents??
Stick with your closed system. Replace the radiator, and either buy a QUALITY pressure bottle (OEM or from gerroffroad.com) OR get the aluminum one from MACs radiator and never have to worry about it again. The closed system is superior IMO except for the pressure bottle. (read this thread: http://www.naxja.org/forum/showthread.php?t=952147 on page 3 i talk about my experiences with the bottle from gerroffroad) Either way DONT get a single core. Do you drive fast alot and barely 4 wheel? Go 3 core. Want to wheel alot (or drive slow)? Go with a 2 core. Last edited by Muad'Dib; June 23rd, 2008 at 11:08. |
#4
what is the advantage of the closed system? I relpaced the oem p.o.s. with a 3 core brass & copper unit so I won't be converting any time soon, but I replaced the tank 4 years ago & now I will be replacing it again as it has a lot of cracks in it. at least I know about Q-Tec now. the dealer nicked me almost $80 for the last one. the only advantage I can see is you don't puke coolant. people tend to have very strong opinions about open v/s closed but no one ever seems to have an explanation why the closed system is superior.could you please enlighten me ?
Thread Tools | |
Display Modes | |
Closed to open fuel system | PurpleCherokee | Jeep Street and Performance | 8 | February 17th, 2008 19:26 |
Using old-style closed rad with open system | rcnerd | Modified Tech Discussion | 13 | November 22nd, 2007 09:49 |
Another Closed T?%Open Cooling System Conversion Success Story | SoCal88XJ | Modified Tech Discussion | 0 | November 4th, 2006 16:30 |
open or closed system? | montysbxj | OEM Tech Discussion | 3 | July 19th, 2005 16:57 |
Closed to open ooling system conversion | woody | OEM Tech Discussion | 4 | July 15th, 2004 21:30 |
