Jeff 98XJ WI
- Butternut, WI
I had previously read that the fuel tank sending unit on my '98 was non replaceable without getting the whole fuel pump. Well, that is not true as I have purchased a new sending unit from the dealer for about $26 and swapped it out with the old unit. Mopar # 1-CBK17552. It came with a new fuel pump gasket, the sending unit with float, two new fuel tank support rods and two nylock nuts! My fuel guage would sometimes drop to zero even though there was half a tank of gas in the tank. Shouldn't do that now. Also, the pressure regulator/filter turned out to have a tiny leak where the nipple for the pressureized line connects to the filter body. I tried JB weld putty on it and it seems to be working...at least for now. A new regulator/filter is $102! Jeff
