OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
broke off oil pressure sending unit
Today i was doing an oil change and when I was taking out the old oil filter i wasn't paying attention and broke off the plastic part of the oil pressure sending unit. I realized what had happened after i turned it on and saw oil spewing out of it. Does anyone know if a new one can be screwed into the metal part of it? Or does the whole assembly have to be replaced. Pictures would help too, thanks
Paul |
#2
Re: broke off oil pressure sending unit
A new sender can be installed.and will be replaced as a unit. once you have the new part on hand, you should be able to see how it is installed and removed.
#3
Be aware that a thin membrane may be the only thing keeping your oil in the engine. You may remove the stub left in the block and temporarily place a M10 screw in to seal the oil in.
Yep, I speak from experience. |
#4
I'm not trying to poke any fun at you...
but that sucks. ![]() |
#5
yeah, you'll have to get a ride to the stealership---you dont want to drive it like that!!
(i also speak from experience! ![]() yeah--the plastic piece had a small metal threaded fitting on it--you'll figure it out really easy when u get the new piece in hand--like a-mechanic said IIRC the part from jeep was about $30-35, but this was 3 years ago. . . good luck! CaptTrev |
#6
I just bought a new one from a local auto parts store for $35(doing a guage swap so I needed one for the new set). I didn't even bother to check with the dealer but I'm guessing they should be anywhere from $40-60.
Good luck. |
#7
![]() http://www.yuccaman.com/jeep/oilsend.html |
#8
i replaced mine 2 weeks ago for $20 at autozone
CODEMAN |
Thread Tools | |
Display Modes | |
