OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
What anti lock brake system is used on a 1992 Cherokee? Is it the same system used on
Thanks
Eric |
#2
Re: What anti lock brake system is used on a 1992 Cherokee? Is it the same system use
Huh?
Its a bendix system iirc |
#3
Get rid of it. Swap in a late model dual diaphram booster/MC
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ? RTFM: Not just an acronym, it's the LAW! nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever blistovmhz: Goddamn Canada. We're all rapists. Don't come here. |
#4
POS system. Swap to a 1995/1996 booster/Master Cylinder. You will have to bend like 1 line and swap the pedal. This gets you a dual diaphragm booster and 1" master cylinder. Get the booster/mc/prop valve as an assembly along with the pedal.
http://wolfenet.org/gallery2/v/Jeep/xj/brakeupgrade/
-- Mark Wolfe N7YMW 95 Sport, locked and lifted. Lakeside, CA |
#5
Hi, saw this thread and wanted to do the swap also as my ABS system went out while driving back in October. So my question is, are 95/96 the only years with dual diaphragm booster, or can I search a later year also up to 97? What parts will I need to scavenge from the donor vehicle. Booster, master cylinder, pro portioning valve, and all the lines to all four wheels? Thanks for the links. Also if you could point me to a how-to or write up about this would be great. Thing is I have to borrow a friends garage and hope to do this job as quickly as possible.
By the way, I drive a 1990 cherokee limited with bendix 9 ABS. |
#6
Thread Tools | |
Display Modes | |
Anti lock brake | boonie | OEM Tech Discussion | 12 | March 9th, 2010 10:12 |
Burping a 1992 radiator & cooling system | mhead | OEM Tech Discussion | 3 | July 10th, 2008 14:59 |
Anti lock brake screw up! | OnceKnotty | Modified Tech Discussion | 12 | July 9th, 2008 07:04 |
reed switch anti theft system (ADE) | azdesertrhino | Modified Tech Discussion | 9 | May 23rd, 2005 21:12 |
How do I disconnect anti-lock brake sensors at rear wheels? | mhead | OEM Tech Discussion | 2 | September 22nd, 2004 14:21 |
