Old June 8th, 2019, 07:54
BAXJDAY BAXJDAY is offline
Re: Voltage Gauge read 19 volts - Digital Meter says 14.2
Originally Posted by Tim_MN View Post
If the dashboard voltage gauge shows 19 volts, there almost always a connectivity issue, most often corroded battery lugs/terminals, internally corroded battery wires, or a loose connection in the charging system.
Today I'm going to take a closer look. Makes sense the voltage would spike if there is a bad ground or fault somewhere. I bet you would bet me on the main cables.
Old June 8th, 2019, 08:03
I quit buying the yellow tops. My CJ ate those things up. I thought they would be best for the winch. I have had excellent luck (so far) with the blues with winches. I too have gone to NAPA batteries and parts in general for that matter. I will only go to AZ, O'R, etc. for oil and paper towels.
Old July 13th, 2019, 18:59
So after cleaning all the cables and connectors, testing everything I could think of, I finally took it into my local Auto Electric shop. Turned out to be the Alternator. I didn't test this because I had just replaced it 3 months prior. Figured I could rule it out. Nope. Brand new NAPA alternator faulted inside. $400 later all is good.
Old July 14th, 2019, 05:56
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Well I would have lost that bet, since an internally shorted alternator is very highly uncommon, but not the first one I have heard about.
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Volt meter = 12 volts for a minute then ~9.5 heyisforhumans OEM Tech Discussion 2 October 9th, 2015 23:12
wiring a tach, temp, and volts gauge. mxracer5647 Modified Tech Discussion 9 November 3rd, 2009 17:39
Voltage meter - Transmission slip NEED HELP Tomynoks OEM Tech Discussion 6 October 27th, 2007 18:59
Where Should my Voltage Gauge Read After... DIGITRUCK OEM Tech Discussion 30 June 24th, 2007 12:44
How do you read an ohm meter? ChipsXJ OEM Tech Discussion 4 September 16th, 2006 08:23
