Old January 9th, 2019, 19:41
oldbill oldbill is offline
Diameter of oil hole in main journal of crankshaft of a 4.0 engine
Does anyone know what the diameter of the oil hole on the main journals of a 4.0L cranksaft are? I'm looking to make a bearing roll out tool
Thanks,
Bill
Crankshaft diameter for main bearings 4.0l engine oldbill OEM Tech Discussion 4 January 11th, 2019 02:55
Crankshaft Bolt Hole Alienspecimen OEM Tech Discussion 1 July 4th, 2016 13:33
is Renix 4.0L valve cover fresh-air CCV hole diameter same as for '94 4.0L & later ? MikeESoc2 OEM Tech Discussion 5 February 14th, 2010 10:01
Detroit Locker Ring Gear Bolt Hole Diameter Blazair SoCal Chapter 0 September 12th, 2009 09:32
Does anyone know std journal diameter fspell220 OEM Tech Discussion 1 July 31st, 2007 19:43
