2000 XJ Blower Motor/Circuit Problem
tsc
Seattle, WA
Hey Guys, I have a 2000 XJ that the blower motor stopped working the other day. The symptoms seem to be the blower worked once or twice when I moved the fan speed switch but then stopped working. Then everything just kind of went out on the panel with the fan speed and temperature, and climate selection.
Now I have changed out the fan relay, the blower motor, and blower motor resistor. I tried a second one out of a 2001 XJ and this didn't seem to solve anything. I have also troubleshooted this by using a dash panel from a 1998 XJ that has the same 3 controls (the temperature control is not cable control in 2000 like it was in 1998)
Now when I turn on the key and change the fan setting, I can hear the blower relay squeal from vibrating really fast. I pulled the blower motor and tested it by connecting it directly to the battery, and putting one in from a 2001 XJ. They both work in the 2001 and when connect to the battery directly.
If I turn the key on I see the back light on the fan bezel on, I am thinking there is an electrical connection some where, does anyone have any ideas on this?
