maybe2fast
- COMMERCE, MI
!!!1
I know this is a million threads old, but I feel I have possibly a unique situation.
I replaced the NSS with a eBay NSS, due to the fact that I broke the old one trying to remove it for cleaning. I had a P0700 and a P0705 with no reverse lights. Pried the aluminum slip piece off the selector shaft and replaced the switch. Starts in P and N and Reverse has lights! Perfect!
Then I clear the codes with the ELM327 bluetooth device and the light goes off, and then comes back on after 1 restart...same codes
I checked the switch connection and found a loose pin in the harness and repaired that (popped it back in) and cleared the codes again...still hard codes come back right away.
Could it still be a bad adjustment with all things working?
