Hello, first post. I just pulled some LCA bolts out of a couple JY WJ's to use on my 99' XJ leafs when I change them this weekend. These bolts are supposed to be 10.9 rated bolts and my question is, the one on the left is slightly longer and has a 10 stamped on the head with a shield symbol (or something similar). Is that bolt also a 10.9 with an odd stamp or did someone swap another bolt in at some point?
You can clearly see the 10 stamp on the left bolt and if you zoom in, you can see the 10.9 on the right bolt. 3 of the bolts I pulled have the 10 on them.
Thanks for any input.
