xjh3
- Moodus, CT
On start-up I keep blowing rubber lines off that I didn't even touch! I've now blown off the hard rubberish lines at the fuel injector rail and connection between the hard lines between the tank and the one going up to the rail. No problems with the rubber lines I installed with the check valve. Along with this, it will also not start sometimes. On one occaision I began to remove one of the lines after the check valve to see if I anything was getting passed the valve and the line came blowing off. After I put the line back on, it started right up.
This tells me (in my mind anyway) that the fuel pump is working and that the check valve is working and that I have pressure. I have heard that if the pressure is off up or down just a little it can throw things off. What I don't understand is what has caused the increase in pressure that is blowing off the lines upon start-up.
Kinda typed this in a hurry but hopefully I got enough info up to atleast get some ideas going. I'm gonna get sick of driving my Mom's caravan real fast. Thanks a ton in advance guys!
